If you want to "use" a global variable in a macro MUST the global variable be passed into the macro as a parameter or can it simply be hard coded in the macro?
I do not want my main program to have losts of loops and jumps in it. I would prefer it to be made up of mainly macro calls.
My situation...
Main program calls MACRO_1 - MACRO_1 loops many (12) times calling MACRO_2 with each loop. Macro 1 is hard coded to input a different Global variable with each loop into Macro 2 as a parameter. These gloabl variables that are hard coded in Macro_1 were not passed as paramaters from the MAIN program.
back to my question at top.....
Ron
Macros & Global variables
Re: Macros & Global variables
Hi Ron
If you firstly select your macro in question then click on Macro -> Edit. This will give you a dialogue where you can specify parameter variables or variables local to the macro.
Hope this helps.
Hope this helps.
