Programming Keypad
Azii
Programming Keypad
Post by Azii »
i'm using flowcode for my GIP but my time is getting the problem so i would kindly ask the following.
I was wondering if someone could build me a flowchart which involves the following criteria :
- Keypad that remembers the code that i put in ( for example : 1 2 3 ) and if that code is typed it needs to go to an output, for example the LED board connected to port C ( C0 )
- if any number besides 123 is given, it needs to go to output C1.
If you need any information about it, please feel free to ask or send me a mail on steve_743@hotmail.com
Kind Regards,
Flowcode Rookie - Steve
Re: Programming Keypad
Hi Steve
Hope this helps. I couldnt get the undo/delete working quite right in simulation as the old string value seems to remain on the display. However it should all work as expected on the hardware.
Keypad Password.fcf
(9.5 KiB) Downloaded 300 times
Azii
Post by Azii »
Thanks alot, really thanks, i'm gonna test it out this Friday because all of the hardware is in school and i'm not allowed to bring it home, i'll give a rapport if it works but like the simulation so far it works very great so far!
I'll try to get the flowcode chart known, so that i understand it, if i have any questions can i post them here or can i maybe send private mail to you?
Thanks alot again!!
Hi Steve
All in a days work :) But thanks.
Any questions post them here and I will do my best to answer them :)
Azii
Post by Azii »
Hey,
Ok no problem i maybe thought it would be easier for you but i'll post any questions on the forum again :)
Azii
Post by Azii »
I've tested the program out today at school but the problem is that the port from the keypad is not connected. could you maybe say which things i all need to edit to place the keypad for example on port D ?
Click on the small menu button on the keypad component.
Select Component connections.
Assign the port you require.
