Strange simulator behaviour in Vista
kkrause
Flowcode v5 User
Has thanked: 1 time
Post by kkrause »
I am running Flowcode for PIC v3.6.11.53 on my PC (Win XP) and my laptop (Vista). The simulator works fine with XP but behaves strangely under Vista. When the simulator is started the variables window appears in front of the main flowchart window, maximised (even if the flowchart main view was not maximised), and has no size/movement controls. There is no way to see the flow diagram and the only way to control it is to use Shift+f5 or f7 to stop or pause - whereupon the view returns to normal. It doesn't seem to matter what the simulation speed is set to. The values of the variables do display and change correctly while running.
Re: Strange simulator behaviour in Vista
I had the same problem with vista take a look at a Temporary solution:-
http://www.matrixmultimedia.com/mmforum ... =21&t=6346
There are also other threads with people have same issue
http://www.matrixmultimedia.com/mmforum ... =24&t=5049
Hopefully this issue will be resolved with V4
