Using microcontrollers with more IO lines
Walbeek
Flowcode v5 User
Been thanked: 3 times
Post by Walbeek »
Hi there,
In flowcode I can sellect several PIC microcontrollers with lots of Pins, for example a 18F6310 that comes in a 64 pin package.
For some projects I need some more I/O than the 40 pin PIC's have, so I need a larger version.
I can sellect the chip, and program it, simulate it with flowcode.
With Flowcode I use E-blocks to simulate and test in hardware.
However, for the larger versions, no hardware is avalable.
How can I program the software into the processor?
Do I need a (Microchip) in circuit programmer for this?
Is there a programmer (like the EB-006) avalable for larger PIC controllers?
Maybe a programmer where I can add a little circuit board with the processor?
Please let me know.
Best regards,
Rinie
Greetings, Rinie
Flowcode V7 user
Re: Using microcontrollers with more IO lines
Hello Rinie
You can use the Matrix EB006 and HP488 boards to program external circuitry. I have attached a picture of the connections that are required. You will have to keep the leads to your external board as short as possible. Around 20cm seems to be ok.
ICSP from DEVBD.gif (16.12 KiB) Viewed 2234 times
The 6 pin header goes to the following connections.
1 - MCLR
2 - +5V
3 - GND
4 - RB7 / PGD
5 - RB6 / PGC
6 - Not Connected
