Display pots value.
Display pots value.
If I'm testing a decision branch based on a voltage or integer value, then I would like to be able to set pot to that value prior to starting simulation from paused.
I believe it would be a good idea for a display window next to pot showing its integer value while simulation is running or paused. There could even be a drop down options box for displaying either voltage, Byte on int.
Re: Display pots value.
To "preset" an input value, add a breakpoint to the first icon in your main flowchart. When you run the program, execution will pause and you can alter the inputs accordingly. Pressing run again will allow the program to continue.
The ADC component does have a "Show value" property which displays the actual ADC input value underneath it. This may not have been in the original v4.0 release, but is there in v4.1.
