Can I shift bit 4 over to bit 3 without shifting bits 0-2
DanDMan
Post by DanDMan »
I have to read a 4 bit binary value from ra0,ra1,ra2, ra4. If I read on only those bits, can I shift bit 4 over to bit 3 without effecting bits 0 to 2?
The only other way I could think of is to read bits into a variable and bit 4 into another variable, then shifting one var and then using OR to combine them into my 4 bit value. Any ideas or suggestions?
Re: Can I shift bit 4 over to bit 3 without shifting bits 0-2
Yes you can do this quite easily.
Simply read the port into a variable using masking so you are only reading the four bits you are interested in - 0,1,2,4.
The using a decision check if the 4th bit is set.
var > 0x0F
If yes then using a calculation icon do the following.
var = var | 0x08
var = var & 0x0F
This simply sets the 3rd bit and then masks the variable so that only the bottom 4 bits are allowed to be set.
If no then you do not have to worry as the 3rd bit is already clear.
Hope this helps.
