reading eeprom ??
numnutts
reading eeprom ??
Post by numnutts »
hi guy's and gals, im trying to read an internal eeprom in pic , have i set up a read macro for this but can i read a range of bytes or have i got to read bit by bit ?? i stored a string of bytes in eeprom and want to display them on the lcd
thanks
Re: reading eeprom ??
You must read and write the EEPROM a byte at a time. The Flowcode component macros will allow you to read a byte when you specify the address and write a byte when you specify the address and the data to be written. If you need to collect an array of bytes than you can do this by creating a simple loop.
Please do not double post onto the forums.
numnutts
Post by numnutts »
Benj wrote:Hello
thanks benj i will give it a go
