Using other IDE libraries
Ondra
Been thanked: 2 times
Post by Ondra »
Good day all.
I would like to know if it is possible to use a library from a different I.D.E'. CCS IDE has implemented PPP in their TCPIP API.
I have a device that I am connecting to the internet over dialup modem. I am using an expensive TCPIP enabled dialup modem. A PIC running PPP would cut the price in half. Any Ideas on this?
Ondra
Re: Using other IDE libraries
Hello Ondra
Libraries for compilers are normally precompiled and as such will require things specific to that compiler in order to work. If you could find some example C source code for the PPP protocol then yes it should be possible to port the code to BoostC.
