Triggering an event with specific sting received via RS232
tanlipseong
Post by tanlipseong »
Hi Benj
In Flowcode V4 section there is a thread with the same Subject, because i use Flowcode3, i post my quention here.
I try to convert the attachment "StringComp.fcf" to Flowcode3 but can not compile with below error, also attached with flowcode3 program.
please help: -
File name: D:\TANLS\FlowCode V3\FlowCode Program\RS232\Communication with PC\StringComp (Flowcode3).c
Generated by: Flowcode v3.6.11.53
Date: Wednesday, November 18, 2009 11:34:18
Licence: Professional
Registered to: Tan Incoils
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F887 "StringComp (Flowcode3).c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "D:\TANLS\FlowCode V3\FlowCode Program\RS232\Communication with PC\StringComp (Flowcode3).c" -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC16F887 -la -c2 -o "StringComp (Flowcode3).pp" -v -d _BOOSTC -d _PIC16
D:\TANLS\FlowCode V3\FlowCode Program\RS232\Communication with PC\StringComp (Flowcode3).c(684): error: missing right paren
D:\TANLS\FlowCode V3\FlowCode Program\RS232\Communication with PC\StringComp (Flowcode3).c(628): error: failure
failure
Return code = 1
FINISHED
StringComp (Flowcode3).fcf
(7 KiB) Downloaded 535 times
Re: Triggering an event with specific sting received via RS232
I think I have spotted the reason for the problem.
You are trying to compare two string variables using a decision icon. Unfortunatley the decision icon cannot do this functionality.
First you will have to use a byte variable and a string manipulation icon. In the string manipulation properties click the functions button, select compare and click use function.
You then need to add your variables.
eg
bytevar = Compare$(in_string, Str1, 0)
or
bytevar = Compare$(in_string, Str1, 1)
The 0 is case sensitive and the 1 is case insensivite.
Then you can use the decision icon on the byte variable. If the byte is equal to 0 then you have a match.
