Problema con el teclado 4x4
Hola, tengo un problema con el teclado 4x4 y no logro saber lo que pasa. He puesto las resisencias como en el EB014 y y sin apretar ninguna tecla me carga distintos valores en la variable ΒΏme podrias dar alguna pista? gracias.
Re: Problema con el teclado 4x4
Roughly translated...
What resistance values did you use?
Do you have a schematic of your keypad circuit you could share with the forum?
Do you have a multimeter you can use to ensure that the input pins are being pulled high by the resistors?
It sounds like the input pins are still floating.Hello, I have a problem with the keyboard 4x4 and profit not to know what happens. I have put the resisencias like in the EB014 and without tightening no key it loads different values to me in the variable podrias to give some track me? thanks.
