problem atm88
ikke
problem atm88
Post by ikke »
Hello,,
I have trouble compiling a atm88, I get the message:
D:\PAPA\flowcode\voorbeelden\test1>"C:\PROGRA~1\MATRIX~1\FLOWCO~1\Tools\MX_bats\..\bin\avr-gcc.exe" -mmcu=atmega88 -Os -funsigned-char -o "D:\PAPA\flowcode\VOORBE~1\test1\druk188.elf" "D:\PAPA\flowcode\VOORBE~1\test1\druk188.c"
In file included from D:\PAPA\flowcode\VOORBE~1\test1\druk188.c:57:
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h: In function 'FC_MARKER':
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:110: error: 'DDRA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:110: error: (Each undeclared identifier is reported only once
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:110: error: for each function it appears in.)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:112: error: 'PORTA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:114: error: 'PINA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h: In function 'icd_byte_tx':
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:329: error: 'DDRA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:331: error: 'PORTA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h: In function 'icd_byte_rx':
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:366: error: 'DDRA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:374: error: 'PINA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:385: error: 'PORTA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h: In function 'wait_clock':
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:401: error: 'PINA' undeclared (first use in this function)
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h: In function 'wait_data':
C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h:413: error: 'PINA' undeclared (first use in this function)
Return code = 1
Please help
Re: problem atm88
If you look at the chip window for the ATMEGA88 then you will see that the device does not have a port A. This is why the various references to Port A are failing. Check your program and your component connections to make sure you are not using port A in your program and the code should then compile correctly.
ikke
Re: problem atm88
Post by ikke »
I don't have anything connected on porta see c-file
//** File name: D:\PAPA\flowcode\voorbeelden\test1\druk188bis.c
//** Generated by: Flowcode v3.3.5.45
//** Date: Monday, December 21, 2009 17:41:18
//** Licence: Professional
//** Registered to: Vandecruys Johan
//** http://www.matrixmultimedia.com
#define MX_AVR
//Defines voor de microcontroller
#define MX_AVR
#define MX_EE
#define MX_EE_SIZE 512
#define MX_SPI
#define MX_SPI_B
#define MX_SPI_SDI 4
#define MX_SPI_SDO 3
#define MX_SPI_SCK 5
#define MX_UART
#define MX_UART_ID
#define MX_UART_UCSRC
#define MX_UART_C
#define MX_UART_TX 1
#define MX_UART_RX 0
#define MX_MI2C
#define MX_I2C_C
#define MX_I2C_SDA 4
#define MX_I2C_SCL 5
#define MX_PWM
#define MX_PWM_PORT PORTB
#define MX_PWM_CNT 2
#define MX_PWM_TRIS1 DDRB
#define MX_PWM_1 1
#define MX_PWM_TRIS2 DDRB
#define MX_PWM_2 2
//Functies
#define F_CPU 20000000UL
#include <avr\io.h>
#include <avr\interrupt.h>
#include <avr\eeprom.h>
#include <MX_util\delay.h>
#include <MX_util\bit_cmds.h>
//Configuratiegegevens
#pragma DATA 0x0, 0xdf
#pragma DATA 0x1, 0xff
#pragma DATA 0x2, 0xff
//Interne functies
#include "C:\Program Files\Matrix Multimedia\Flowcode_AVR\FCD\internals.h"
//Macro functie declaraties
//Variable declaraties
volatile char FCV_OUTPUT;
volatile char FCV_DRUKC1;
volatile char FCV_DRUKCO;
//Toegevoegde definities
//Macro implementaties
//Toegevoegde implementaties
int main()
//Initialisatie
MCUSR=0x00;
WDTCSR=0x10;
//Interrupt initialisatie code
//Loop
//Loop: While 1
while( 1 )
//Input
//Input: C0 -> drukco
DDRC = DDRC & 0xfe;
FCV_DRUKCO = ((PINC & 0x01) == 0x01);
//Input
//Input: C1 -> drukc1
DDRC = DDRC & 0xfd;
FCV_DRUKC1 = ((PINC & 0x02) == 0x02);
//Decision
//Decision: drukco?
if( FCV_DRUKCO )
//Calculation
//Calculation:
// output = output + 1
FCV_OUTPUT = FCV_OUTPUT + 1 ;
//Output
//Output: output -> PORT B
DDRB = 0xFF;
PORTB = FCV_OUTPUT;
mainendloop: goto mainendloop;
Re: problem atm88
Where did you get your installation for Flowcode AVR from?
Your compiled C code states v3.3 but your error messages are showing an error relating to a function that is only included in version 4.
Have you installed version 4? Have you mixed up the files at all.
Can you uninstall your version 3 and re-install to see if that fixes the problem.
ikke
Re: problem atm88
Post by ikke »
First: THANK YOU!!!
Yes it worked.
I got my copy from Elektor.
I first installed the free copy from the website and than simply put in the licensekey from the DVD.
Greetings.
Re: problem atm88
Hello Ikke
Great glad your all up and running now. Thanks for letting us know.
ikke
Re: problem atm88
Post by ikke »
Hello, I am still can't put my program into the atm88 directly from flowcode. When using avr studio it goes.? I keep receiving:
Launching the programmer...
C:\Program Files\Matrix Multimedia\Flowcode_AVR\Tools\MX_bats\avrc.bat m88 avrispmkii usb "druk188bis.hex" 0 3 223 -1 -1
D:\PAPA\flowcode\voorbeelden\test1>"C:\PROGRA~1\MATRIX~1\FLOWCO~1\Tools\MX_bats\..\AVRDUDEusb\avrdude.exe" -p m88 -P usb -c avrispmkii -U flash:w:"druk188bis.hex"
Error returned from [avrdude]
Return code = 1
Verzenden van de flowchart naar de microcontroller is mislukt. Controleer de opties voor de programmeersoftware en de verbinding tussen PC en processor.
FINISHED
I allready looked at the posts on the forum but could not solve the problem on my one.
If anyone can help me?
Allready THANKS
ikke
Re: problem atm88
Post by ikke »
Sorry for the last reply. I now use the stk500 and everything is working.
Sorry
