Understanding Programming
TerryV
Post by TerryV »
As a beginner I have written a small C program which simply turns on the LEDs on the V3 development board.
The program compiles and down loads successfully but functions differently to what I expected:
My understanding was that an o/p will stay hi unless it is turned off, this does not appear to be the case, also having reached the end, the program appears to randomly restart with out my resetting.
Can some one explain?
Many thanks
Re: Understanding Programming
PICs work in 8-bit therefore if you modify one bit on a port then you are actually modifying an entire port. To get around this you could use something like this.
portb = portb | 0x01; //sets bit 1 of port b
portb = portb & 0xFE; //clears bit 1 of port b
The program counter on the device that fetches instructions will keep going even if your program does not. Therefore at the end of your program you must have a infinite loop to stop the program memory wrapping around back to the start or worse.
while (1) ;
