I'm trying some supplemental asm code in V4 for PIC but can't get it to compile without errors.
Example:
asm
movlw 0xff,0
movwf WPUB,0
I have verified that WPUB is recognized (if I use _WPUB I get 'unrecognised blabla'), so I guess I'm making a syntax error.
Can anybody point me in the right direction?
tia,
jan didden
asm syntax for V4 suppl code
- Flowcode v5 User
- Has thanked: 19 times
- Been thanked: 16 times
Re: asm syntax for V4 suppl code
Strangely enogh, while:
asm
movlw 0xff
movwf WPUB
gives an error,
asm
movlw 0xff
movlw WPUB
doesn't.
Seems movwf causes the error, no idea why....
jan didden
asm
movlw 0xff
movwf WPUB
gives an error,
asm
movlw 0xff
movlw WPUB
doesn't.
jan didden
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
WPUB could simply be a definition of the register location, in which case it will simply be a number (which is why movlw works ok).
Have you tried "_wpub" or "wpub"?
- Flowcode v5 User
Yes, 'movwf _wpub' works. In fact, when I did 'movwf wpub' I got the error message: 'did you forget the _ before wpub?'. Neat (but rare....).
But now I have somehow to find out that it interprets _wpub correctly as the reg location (which it is). Wish I could find the include file where this stuff is defined.
Edit: found the .h header with the reg definitions.
Also, when I tried 'iorwf option_reg' it also gives an unspecified error. And no, _option_reg doesn't clear it.
I checked the .fcd and 'option_reg' is used there, so it is known by the assembler I guess.
This trial and error isn't really a lot of fun; isn't there really any help file that addresses the syntax for asm and/or C supplementary code?
jan didden
jan didden
- Flowcode v5 User
Another step: the assembler doesn't use a default destination for an operation (which is what the microchip assmbler MPASM does), so you need to always specify it explicitly:
'iorwf _option_reg' causes an error, 'iorwf _option_reg, F' (or W) assembles OK.
jan didden
jan didden
- Steve
Hi Jan,
Thanks for the info. Your best source of information like this is probably the BoostC forum:
http://forum.sourceboost.com/
