Possible Upgrade to Version 4
Dirk Bubley
- Has thanked: 14 times
- Been thanked: 12 times
Hi Matrix Team,
i`m using FC Version 3 very succesfull for now over 2 years and iΒ΄m realy happy with it!!
One point wich iΒ΄m missing in FC Version 3 is a floating point calculation without writing C-Code.
This would be very helpful because iΒ΄m doing a lot of voltage measurements with the PIC ADCΒ΄s and putting the result to the LCD.
Question will Version 4 support my need??
BR
Dirk
BR
Dirk
Re: Possible Upgrade to Version 4
Hello Dirk
Yes Flowcode v4 for PIC and Flowcode for AVR and ARM have full floating point support built in as standard. Flowcode v4 for PIC uses Floating point functions similar to the string manipulation functions whereas AVR and ARM have standardised Float manipulation without the need for functions.
Dirk Bubley
Hi Ben,
many thanks for the fast reply! Is there any example how it looks like??
BR
Dirk
BR
Dirk
Hello Dirk
There is a marketting datasheet on v4 available from here:
http://www.matrixmultimedia.com/datashe ... C-60-4.pdf
Dirk Bubley
i knew the datasheet but i thoght more into the direction of a documentation.
Is it possible to check the floating point function with Version 4 Demo Software??
BR
Dirk
BR
Dirk
Hi Dirk
Yes the floating point should work fine with the demo version. You can use the floating point functions when using the BoostC compiler or if you decide to switch to the HITECH compiler then the standard floating point operations are supported as they are in the AVR and ARM. See the articles section of the forum if you want to configure v4 for use with HITECH.
Dirk Bubley
Hi Ben,
it works great in the Version 4 Demo. Exact what i need. I just have to reduce the number of digits on the right side of the comma, but that fine tweaking.
So i think i will purchase shortly a Version 4 prof.
Is it possible to use Version 4 under Windows-7 ?? Because i like to setup a new PC workstation!!
BR
Dirk
BR
Dirk
Dirk Bubley
Hi Steve,
i assume Version 4 will run either in 32 or 64 Bit under Win-7!! Right??
BR
Dirk
BR
Dirk
