Gentlemen,
I am well pleased Flow Code V4.2.
But if I want to load programs with V4.2 I have great problems with the macros.
Many of the macros do not work and I need to export them first and then import then it just right.
That can not be what I hope.
Greetings Henk.
V 3.xx and V4.2
Re: V 3.xx and V4.2
Yes, I really can not.
Programs that have been made in V3.xx in V4.2 must be read normally.
Henk
Henk
Re: V 3.xx and V4.2
Hello Henk
If you have a program that was 100% positivly created in V3 that also does not work or import correctly with v4 then please can you send it to us for testing.
Re: V 3.xx and V4.2
I have created this program with V3.xx I want to load this programm with V4.2 I get an error immediately.
Flow V4.2 Code says>
Connection and properties for the following components are failed to load : LedSeg4.
The following macro wil be ignored because is no longer used ADC0:: sample ADC.
I don't no why!
Henk.
I don't no why!
Henk.
- Henko_5f5.fcf
- (6.5 KiB) Downloaded 300 times
Re: V 3.xx and V4.2
To solve the errors are simple.
Re-'The following macro will be ignored because is no longer used ADC0:: sample ADC'. This is because in V3 you need to sample the ADC first. In V4 you don't. So error message is just telling you, Sample ADC is no longer necessary for Flowcode to work OK so it is going to ignore that. You can just delete Sample ADC in V4.
Re- Connection and properties for the following components are failed to load : LedSeg4. All that means is LED segment is not connected to any ports. Just right click on the LED segment (on panel) select connections, and connect to correct ports and bits.
You do have a point. Although you can easily get Flowcode V4 to work, it would be better if 1, Sample ADC is auto removed, and 2, connections of ports are retained.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: V 3.xx and V4.2
Medelec's answer is correct, thanks for this.
The reason the "SampleADC" is retained in the code is because there are situations where you might want to sample the ADC at a different point to actually reading the return value, although I think this would be very rare. Leaving these macro calls in will be no problem at all because they are simply ignored by Flowcode.
The 7 segment components were totally re-written in V4, and the new V4 components are unable to "understand" the saved information for the V3 components - hence the need to redefine the pins and properties.
We do pay a lot of attention to ensure that V3 programs will load under V4 without problems. Unfortunately, these two issues are (I think) the only issues that we could not resolve - so I think we actually did ok!
Re: V 3.xx and V4.2
I do agree about doing ok. There must be a lot of obstacles to overcome when trying to achieve backward compatibility. I would be happy with assigning pins when LED segment is displayed. I don't leave the Sample ADC, only because of window space, i.e whats the point of having it, if its redundant. But as you say it can be left and totally ignored.steve wrote:We do pay a lot of attention to ensure that V3 programs will load under V4 without problems. Unfortunately, these two issues are (I think) the only issues that we could not resolve - so I think we actually did ok!
So since matters can't be resolved and to be honest is no big deal at all, overall the conversion to from V3 to V4 gets a big thumbs up from me!
