TCPIP samples not working - posted incorrectly
kdoney34711
Has thanked: 1 time
Post by kdoney34711 »
Sorry, I posted this in miac when it should have been posted here.
After getting errors I ran Reg_V4_Comps.bat and Components_V4.reg files with no relief.
tcpip examples
udp, firewall, arp, receive_html, send_html
"one of the components is not registered" then
"memory protection violation" then crash
smtp
add defines component is no longer available please use supplementary code
features instead
Ping works with no complaints.
An entire system description is attached. I am running the latest release of v4 for pics.
sys.zip
(38.39 KiB) Downloaded 306 times
Re: TCPIP samples not working - posted incorrectly
kdoney34711
Has thanked: 1 time
I made the change from TMR0 to tmr0 on lines 921 and 922 in pic_tcp_ip.c in the component directory of my flowcode installation and this made no difference. I still get crashed when using the tcpip examples.
In the thread there is mention of updated files. I will ask Ben to post them here shortly.
Ok these examples should all open correctly in v4. In some of them they might have been using the thermometer component. If you get a message about this then you can simply add a ADC component to the program and then change any component macros that reference the thermometer to reference the ADC instead.
component examples.zip
(166.23 KiB) Downloaded 335 times
kdoney34711
Has thanked: 1 time
Thanks. These work fine.
