I want to use a program written with flowcode V3 with flowcode V4. WhenI try to load the file I get the following messages
Flowcode could not load one of the components in the file because it is not registered on this machine. Install the necessary component before opening this file.
followed by
ERROR Access violation at 0x0046CB16 (tried to read from 0x00000020) PROGRAM TERMINATED
The program uses keypad, lcd, adc components all of which appear in the component toolbar of V4
any ideas?
PS. any luck with speech component?
thanks Gary
Using FlowcodeV4 with V3 files
g-slocombe
- Has thanked: 7 times
- Been thanked: 4 times
Re: Using FlowcodeV4 with V3 files
Hello Gary
I have hopefully fixed the speech component now and it should work ok with the larger memory devices. Please copy the attached component code file into your Flowcode v4\Components directory and then restart Flowcode to allow the changes to be loaded.
Regarding your V3 to V4 problem please can you attach the file so we can have a look.
- PIC_Speech.c
- (13.86 KiB) Downloaded 301 times
g-slocombe
Have enclosed the file for you to look at.
Thanks Gary
Thanks Gary
- GaryTank2.fcf
- V3 to V4 problem
- (12.49 KiB) Downloaded 295 times
Hi Gary
The program must have been a version 2 program, I have now converted it to a v3 program and it will now open correctly in v4.
Let me know if you have any problems and let me know how you get on with the updated speech component.
- GaryTank2.fcf
- (18.13 KiB) Downloaded 281 times
g-slocombe
