ISCD and ICD
Taurus
Flowcode V4 User
Has thanked: 3 times
ISCD and ICD
Post by Taurus »
Idea
Is it possible to make one ISCD and ICD (programmer/debugger) that can be used for private developments and the EB block programmers that are available now.
In this option I am very interested, I think I am not the only one.
When I read it right you already have developed this software for the EB006 V7 and for the Picflow, is it possible to put these together. All in one.
This has many advantages:
The ISCD and ICD (programmer/debugger) can also be connected on this board and be used for private developments.
In that case it maybe is an idea is to make a new EB block board without the programmer or maybe you already have developed it, think about the ECIO board.
The new E-block board then also could be used with other programmers or software.
I have an EB-006-00-6 board.
Taurus
Re: ISCD and ICD
Hello Taurus,
The EB006 v7 board can be used for ICSP programming and ICD. There should be a schematic on the forums showing how the ICSP is done. You basically have to make your own custom cable to do this. Once you have the ICSP connected the ICD should also work straight off.
http://www.matrixmultimedia.com/mmforum ... 815#p14815
