External memory
armagon29
Been thanked: 2 times
External memory
Post by armagon29 »
Dear All:
I need to write info (ADC value) into an external memory 24LC254 (i2c protocol) but I not sure if it is possible, FC v3 has a especial macro (Beta) for I2c devices?, but how can I use this memory, If this kind of device is not property, which one and how does it work?
Re: External memory
This is taken from the help file for the I2C component.
A typical IΒ²C device (24 series EEPROM)
Here is how to send and receive data to and from a typical IΒ²C device.
Sending Data
Output a start condition //Starts the device listening to the IΒ²C bus.
Transmit the External Device address with the LSB cleared. //Enables the device and sets to write mode.
Transmit the Internal address. //Sets the address to start writing data to.
Transmit a byte of data. //Device will acknowledge and increment internal address until page limit is reached
Output a stop condition //Stops the device listening to the IΒ²C bus.
Note. When writing to a page of memory make sure to only write within that page as if you carry on writing bytes the internal address will wrap around and begin overwriting the first bytes.
Receiving Data
Transmit the Internal address. //Sets the address to start reading data from.
Output a restart condition //Restarts the device listening to the IΒ²C bus.
Transmit the External Device address with the LSB set. //Enables the device and sets to read mode.
Receive a byte of data with last byte 0. //Device will send data and increment internal address until page limit is reached
Receive a byte of data with last byte 1. //Device will send data.
Flowcode v4 has built in functions to do this for you.
