Timer
Has thanked: 1135 times
Been thanked: 299 times
Timer
Post by jgu1 »
Hi!
Can anybody help me. I want to make a timer, not a wait. I am making a program where I am using Macro´s. But every 5 minute I want to set a flag so I am able to enable a Macro. I have already used one interrupt with timer0.
Is it possible to make a timer witch run wihtout interrupt, and please without C code?
Thanks i advance.
Best regard
Jørgen
Re: Timer
Interrupts are used for a timer if your program is required to do other things whilst timing is carried out.
If you want a 5 minute non-interrupt timer, so program justs waits until time period has elapsed then try this way:
http://www.matrixmultimedia.com/mmforum ... =26&t=6967
If it was me and I would like to keep setting a flag every 5 minutes and performing other functions then I would use timer 1, since already using timer 0.
Albert38
Has thanked: 2 times
Re: Timer
Post by Albert38 »
If you already used timer0, you know the frequentie on witch this timer0 works. Just add a counter to it and place the routine you want to run every 5 minutes behind a "if" before this "if" you make a calculation "{LV} = Counter MOD {the number of times your timer0 is run in 5 minutes}" Now the "if" has to go true loop "yes" when the {LV} is 0
Re: Timer
Post by jgu1 »
Hi!
Thank you both of you. I will try.
Regard
Jørgen.
Re: Timer
Albert38 wrote:If you already used timer0, you know the frequentie on witch this timer0 works.
That is a good point!
You said your already using int0, here is how you can utilise timer 0 to have a 2, 3 and 5 minute timer simultaneously. I have also included a Minute variable to set for how ever minutes you like.
You can also add as many different timers as you like.
Different Timings LED Test1.fcf
(8.5 KiB) Downloaded 376 times
Re: Timer
Post by jgu1 »
Thank you Albert38. Very good examble, it works
Regard
Jørgen :P
