project on zigbee module
For anyone wishing to receive additional help with a project or simply looking to hire an embedded contractor we have a few contacts who would be more then willing to help.
arush
Post by arush »
i am using this flowcode version-4 software, with the zigbee solution kit.
i have to got the datasheets for zigbee board(eb051-00-1),picmicro MCU multiprogrammer(eb006-00-5),spi memory and d/a board(eb013-00-2), keypad board, graphic lcd display(eb043-00-1), led board(eb004-00-2), and have one sensor board.
but as per i think i require only first three boards. as i need to transmit audio from one end of pic (coordinator side) to the other end that is the router/end node side.
Re: project on zigbee module
Hello Arush,
Have you looked through the Zigbee manual available from here?
http://www.matrixmultimedia.com/lc_adva ... .php#EB538
Transmitting data fairly simple using Zigbee. The main task is to get the nodes connected up and once you have done that you can start transferring the data. Though I must say that Zigbee is not really suited to audio applications. Bluetooth has Audio built right into the standard whereas Zigbee is for low level control. Eg turn off light 1.
