Simpel Kipfunction
Has thanked: 1135 times
Been thanked: 299 times
Simpel Kipfunction
Post by jgu1 »
Hello!
I am making a program which I need a Kip function like the attachment. It must be easy. It is also, but I just thought of this simple function fills the program very much.
Are there any "here" has a suggestion for a more simple program for this function?
Preferably without C code, since it is not my strong point.
Thanks in advance.
Jørgen :P
KipFunction.fcf
(12 KiB) Downloaded 314 times
Re: Simpel Kipfunction
This is my fist attempt. I have reduced your program size from 12K to 7K.
I will see if I can think of a better way.
KipFunction2.fcf
(6.5 KiB) Downloaded 310 times
ksor
Post by ksor »
Take a look at the "Componemt macro" and insert this ikon in your flowchart, dobble-click on it and you will see a list of elements.
Mark each element and see what macros you can use for each element.
Hope this gives you a hint !
Best regards
KSor, Denmark
Sean
Has thanked: 6 times
Been thanked: 44 times
Post by Sean »
I have compiled the first two programs in this thread to check the program sizes being reported.
The original program compiles to 190 bytes of program memory and the second program to 145 bytes.
The files that change from 12K to 7K between the two versions are the Flowcode source file (.fcf). These are used by Flowcode but are not downloaded to the target device.
Details of the program downloaded to the target device are reported during compilation. This information is also saved along with the other project files created by Flowcode as a .msg (.txt) file.
Good point! 2nd program still smaller though :P
Phew! lol
Although I did get the impression, it was more about the amount of icons that was in the program, rather than both size of flowcode file and amount of program memory used up. So my logic is 7K instead of 12K = less icons.
Sean
Post by Sean »
We hope that the size of the files created and saved on the PC by Flowcode is not considered to be a problem.
The main aim is to create efficient code for downloading to the target device.
Several factors will affect the size of either the Flowcode project files, the target program, or both.
Examples:
Custom images and comments increase the size of the Flowcode programs without affecting the memory used in the target device. These are usually considered to be beneficial for program clarity and maintenance.
ICD functionality, variable type selection, C code, and inclusion of external files will affect the size of the target device program more than the Flowcode project files.
Post by jgu1 »
Hi All!
Thanks for your help, I'm glad that I can get some expert help here. I can see that the function is more simple now and the program does not take up so much. 8)
For you Ksor, I can see you are from Denmark maybe you live in Korsor? I live in Odense, but works in Korsor. If you wish we could exchange email addresses and share experiences together? :roll:
Greetings
Jorgen
ksor
Post by ksor »
jgu1 wrote:Hi All!
Greetings
Jorgen
Hi Jorgen (maybe Jørgen in danish ?)
I live in Aarhus V ... so quit a distance anyway, but sometimes it's much easier to explain a special problem in our first language - danish - so here is my address:
keld DOT soerensen SNABELA os DOT dk
Best regards
KSor, Denmark
