RANDOM
electron67
Has thanked: 106 times
Been thanked: 48 times
RANDOM
Post by electron67 »
How use Random; CALCULATION: A0 = RANDOM()
Simulation is Ok, but when copile, is error (support technical)
Re: RANDOM
We need a bit more information to help you with this. Which software product are you using (and which version)?
Also, please attach a program to this forum which exhibits this problem.
Re: RANDOM
Steve.
You can replicate the issue using latest version of Flowcode V4 (not tried with other versions). Use the Random() function within a calculation box.
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "Random Number Error.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\pp.exe "m:\Random Number Error.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include -d _PIC16F88 -la -c2 -o "m:\Random Number Error.pp" -v -d _BOOSTC -d _PIC16
m:\Random Number Error.c(80:19): error: unknown identifier 'rand'
m:\Random Number Error.c(80:19): error: failed to generate expression
m:\Random Number Error.c(80:19): error: invalid operand 'rand()'
m:\Random Number Error.c(80:17): error: failed to generate expression
Random Number Error.c success
failure
Return code = 1
FINISHED
Random Number Error.fcf
(3 KiB) Downloaded 337 times
Re: RANDOM
I see the problem. To use the random number function, you will need to add the following line to the "defines" section of the supplementary code:
#include <rand.h>
(52.94 KiB) Downloaded 3328 times
electron67
Re: RANDOM
:idea: Tank you for the answer, I can read good english, but not very well write english.
In the future, I write in spanish :?:
Tank you
