16F72X fcd files require correcting
I was using a target chip of 16F737 ,and that is working great. Then I wanted to change target to a pin equivalent 16F722 which required modifying (thanks Benj for that). but unfortunately that chip has not got enough memory capacity. Ben You said a pin was disconnected, I now know why that is the case.
the 16F72x has not got the correct number of ADC channels. Channel ANA10 and ANA12 are missing. Since 16F737 has correctly got those channels in fcd, when changing target to 16F722/3 then pin automatically gets disconnected since wrongly ANA12 did not exist.
I have edited and attaced a 16F723 to include all ADC channels and IOC (since that part is also missing). I am now using that chip, and have found the analogue part (ANA0 and ANA1) on my simulator is not working. Would someone mind having a look at this file and correcting any problems that could be left outstanding.
Thank you, it would be appreciated . :-)
P.s
Not checked all the 16F72x series, so I can only say 16F722 and 16F723 are not correct.
16F723.fcd
(10.25 KiB) Downloaded 356 times
Re: 16F72X fcd files require correcting
Hi Medelec,
I will look into the problem and get back to you.
Many thanks.
Hi Medelec.
I have updated the ADC's so they should work on the smaller 16F72x devices. I havwe also added the extra PORTB interrupt to the FCD files as standard.
Let me know if ADC channels 0 and 1 are still misbehaiving and I will look into this further.
FCDUpdate.zip
(19.1 KiB) Downloaded 356 times
Hello Ben.
Thank you for the files you posted, appreciated as always.
Unfortunately after some more testing, none of the analog channels are working. That is still the case with the latest definition file you posted.
I have included a test Flowcode, and the generated c file. I would be really grateful for any assistance in solving this.
Thanks again.
ADC test using LCD 723.c
(30.84 KiB) Downloaded 312 times
ADC test using LCD 723.fcf
(14 KiB) Downloaded 337 times
Hi Medelec,
Right I have found the problem. The ADC18 component C file was looking at a static define for the ADC value register address rather then the actual value itself.
Here is the fixed component.
PIC_ADC_18.c
(9.39 KiB) Downloaded 357 times
That's Great! Thank you Ben, your a star! ADC channels are confirmed to be working now. 8)
