16F72X fcd files require correcting
Posted: Sun Jun 20, 2010 8:18 pm
I was using a target chip of 16F737 ,and that is working great. Then I wanted to change target to a pin equivalent 16F722 which required modifying (thanks Benj for that). but unfortunately that chip has not got enough memory capacity. Ben You said a pin was disconnected, I now know why that is the case.
the 16F72x has not got the correct number of ADC channels. Channel ANA10 and ANA12 are missing. Since 16F737 has correctly got those channels in fcd, when changing target to 16F722/3 then pin automatically gets disconnected since wrongly ANA12 did not exist.
I have edited and attaced a 16F723 to include all ADC channels and IOC (since that part is also missing). I am now using that chip, and have found the analogue part (ANA0 and ANA1) on my simulator is not working. Would someone mind having a look at this file and correcting any problems that could be left outstanding.
Thank you, it would be appreciated .
P.s
Not checked all the 16F72x series, so I can only say 16F722 and 16F723 are not correct.
P.s
