porte on 18F4685
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
porte on 18F4685
Hello Team
In simulation the loop : porte 2:0 off > 10ms wait > porte 2:0 on > 10ms wait ... works ok.
after compile to chip dont work on hardware.
If i compile to chip the loop : porte 0 off > 10ms wait > porte 0 on >10ms wait > ... work ok
If i compile to chip the loop : porte 1 off > 10ms wait > porte 1 on >10ms wait > ... dont work
If i compile to chip the loop : porte 2 off > 10ms wait > porte 2 on >10ms wait > ... work ok
please help
regards wolfgang
please help
regards wolfgang
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: porte on 18F4685
This seems really strange. Could it be a problem with the hardware? If not, could the peripherals that are multiplexed with that pin be interfering with its output? It has these alternate functions: AN6 (ADC input), C1OUT (Comparator 1 output) and WR (PSP write enable input). The FCD seems to disable the ADC and Comparator appropriately. The PSP peripheral is controlled by bit 4 of TRISE - is this being set?
If you're still having problems, please replicate the problem in a very simple program and post the C code file here.
saschech@gmx.de
Hello Steve
There is no hardware .
If i put in a macro with 0 > pe1,nothing work.
If i delete macro macro with 0 > pe1,
pe0 flash 10ms ok
pe1 i show on the scope f < 1µs
pe2 flash 10ms ok
//Initialisierung
adcon1 = 0x0F;
cmcon = 0x07;
//Interrupt-Initialisierungs-Kode
//Output
//Output: 0 -> E1
trise = trise & 0xfd;
if (0)
porte = (porte & 0xfd) | 0x02;
else
porte = porte & 0xfd;
pe0 flash 10ms ok
pe2 flash 10ms ok
//Initialisierung
adcon1 = 0x0F;
cmcon = 0x07;
//Output
//Output: 0 -> E1
if (0)
else
- pe0 ok- pe1 nok - pe2 ok.c
- (3.67 KiB) Downloaded 307 times
- pe0_nok-pe1_nok-pe2_nok.c
- (3.67 KiB) Downloaded 325 times
- Steve
The C code files are identical.
Also, try putting the following in a C code icon at the beginning of the flowchart:
trise = 0x00;-
saschech@gmx.de
Hello Steve
After i do these it dont work.
I put in the c-code on different position in the flowchart,no work
Regards Wolfgang
Regards Wolfgang
- testporte.c
- (3.88 KiB) Downloaded 323 times
Hello Wolfgang.
Did you paste the correct two C files?. Steve is right. I loaded your two files in a program which compares two files, and highlights any differences.
Only two differences are in lines of:
Name
Date. All others lines are 100% identical.
Name
saschech@gmx.de
Hello Medelec35
if i put in onetime "trise = 0x00" nothing work......
Regards Wolfgang
Regards Wolfgang
saschech@gmx.de
Hello Steve
Is there a ather reason to initial porte?
Regards Wolfgang
Regards Wolfgang
- (89.66 KiB) Downloaded 1468 times
Hello Wolfgang,
I have experienced some similar problems in the past and think it may be due to specific silicone problems with the chip or at least the specific silicone inthe chip you are using. I had I/O that simply would not behaive on some chips but worked well on others from a later batch. In the end I got around the problem by using a bit of C code like this.
set_bit(late, 1);
delay_ms(10);
clear_bit(late, 1);
delay_ms(10);
or like this
late = late | 0x02; //set bit 1 of port e
delay_ms(10);
late = late & 0xFD; //clear bit 1 of port e
delay_ms(10);
All this does is try to use the lat input for the register instead of the port register that the Flowcode I/O icons use.
set_bit(late, 1);
delay_ms(10);
clear_bit(late, 1);
delay_ms(10);
or like this
delay_ms(10);
delay_ms(10);
