violation error during compiling
Violation error at 0x4AA47A (tried to write to 0x00030E50)
during compiling.
I get above message during compiling (return code 1073741819)
I tried this with PIC 16F88 and the 16F877A, both same problem, in simulation it's works OK
Can somebody help?
Kindly regards
Rob
during compiling.
Can somebody help?
Kindly regards
Rob
Re: violation error during compiling
Are you using an interrupt? if so is has it got all correct settings? If you would like to post, it can be tested for you.
Sorry for my late reaction, I had forgotten the Notify
no, I haven't program an Interupt!
kindly regards
Rob
kindly regards
Rob
Hello Steve,
only with a particular program, if you want I attach the flowcode
Kindly regards
Rob
Kindly regards
Rob
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
The good news - I've managed to replicate your problem.
The bad news - it looks like a problem with BoostC rather than Flowcode.
If you delete the calculation icons in the main macro that set the speed and address tables, the program compiles ok. So this is where you need to focus your attention.
Hello Steve,
I removed all the callation issue, after compiling there was another error message (returncode 2) Memmory allocation error.
Question, can I better use an other chip, so yes which one?
calculation pictogram:
Do you know e better solution to setup a database, because now I have to store each bit in a separate variable!
thanks for your great and fast help
Rob
Rob
- Steve
If your data is constant, you could create a lookup table which will use program memory space instead of RAM. I think one or two of the articles show examples of this.
Another trick is to use masks. 8 boolean variables can be represented within 1 byte and accessed using the masks 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80. Here's how to set them (the byte variable "flags" contains 8 separate booleans):
And here's the check:
flags = flags OR 0x02 [sets the 2nd bit to 1]
flags = flags AND (NOT 0x02) [sets the 2nd bit to 0]
if (flags AND 0x02) [true if the 2nd bit is set]
Hello Steve,
Thanks, I have found something on the forum about this subject, maybe it's useful
Kindly regards
Rob
Kindly regards
Rob
