several problems with PIC18F25J50 the second
HjH
Been thanked: 2 times
Post by HjH »
I have a PIC18F25J50 controller.
I have designed a RS232 programm. This programm run correct if I write a constant 'A' in the variable Input of the componenten macro RS232. If I write a variable with 'A' in the Input of the componenten macro RS232 no characters send the Pic to the RS232.
The problem you can better see in the sample
Flowcode3.fcf
(7 KiB) Downloaded 320 times
Can you help me
Tris
Flowcode V4 User
Re: several problems with PIC18F25J50 the second
Post by Tris »
try using a string manipulation box and putting m_Send = "test," in it, instead of doing the c command box with FCV_M_SEND = 'T'.....
The problem might be to do with the way commas are interpreted inside strings. You may have to nullify the comma by either sending the ASCII number 44 as a byte or you may be able to use it in the string by adding a command character slash.
eg.
m_Send = "test\,"
