Accessing Virtual Drives
KaseyN
Post by KaseyN »
I tried searching, I hope this topic has not already been covered.
I have flowcode through the University of DeVry. When I go to save my file the lab requests that I save it to a Virtual drive labeled 'C$ Client (V:)' or close to that. When I try it says that 'V: is not accessible access is denied'
Then when I try to compile the code to hex, after saving to a hard file, it fails. I need to compile to hex but I tried compile to chip and it still failed.
What am I doing wrong? It is already halfway through the week and I am no closer to getting this assignment done.
Thank you for the help,
Kasey
Re: Accessing Virtual Drives
Hi Kasey,
This sounds like it is a problem with the way the Citrix server is set up. We've never had this support request before, so I guess it does work for other users.
Your supervisor or administrator might be able to help better than we can. I'm sorry I can be of better assistance to you.
KaseyN
Post by KaseyN »
Thank you for the reply, I will contact them and see.
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Post by saschech@gmx.de »
Hello Steve
A long time behind i tell matrix , on my network, Flocode dont compile....
The answer was it must go
on my two pc 1x homeserver 1x win7 pc it dont work again .....
on my master-pc it work ok
Regards Wolfgang
(47.67 KiB) Downloaded 1718 times
(42.48 KiB) Downloaded 1718 times
saschech@gmx.de
Has thanked: 1 time
Nobody have a idea why i have the error?
Regards wolfgang
Sorry, Wolfgang. I thought your post was a reply to this topic rather than a question in its own right.
I think it may be that accessing a UNC path might not work and you need to map the network drive. Alternatively, copy the file to your local hard drive and work with the file there.
