I am getting the error reported below when trying to compile the following asm-block in flowcode:
char temp;
asm
BSF _status, RP0;
MOVLW 0x0;
MOVWF _trisa;
BCF _status, RP0;
MOVLW 0x03;
//MOVWF 0x20;
MOVLW 0x20 ;
MOVWF _temp ;
SWAPF _temp,1 ;
MOVF _temp,0 ;
MOVLW 0x01;
SUBWF 0x20,1 ;
MOVF 0x20,0;
MOVWF _trisa;
The Dutch messages do not give any interesting information related to the error, so I will not translate them.
Any help would be greatly appreciated.
Kees
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "767-07.2-14.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
767-07.2-14.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe D:\Archief\projects\Dirksen\pmc\tests\767-07.2-14.c -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC16F88 -la -c2 -o D:\Archief\projects\Dirksen\pmc\tests\767-07.2-14.pp -v -d _BOOSTC -d _PIC16
D:\Archief\projects\Dirksen\pmc\tests\767-07.2-14.c(95): error: error in built-in assembly
D:\Archief\projects\Dirksen\pmc\tests\767-07.2-14.c(96): error: error in built-in assembly
767-07.2-14.c success
failure
Return code = 1
Flowcode kan de C-code niet vertalen vanwege de volgende fout:
Als de flowchart C-code bevat, controleer die dan zorgvuldig. Als de flowchart geen C-code bevat of als die gegarandeerd vrij is van fouten, neem dan contact op met de technische ondersteuning.
FINISHED
compiler / linker failure in asm block
Re: compiler / linker failure in asm block
I have added another C variable to take the place of memory location 0x20 and the code is compiling ok now.
char temp;
char temp2;
asm
BSF _status, RP0;
MOVLW 0x0;
MOVWF _trisa;
BCF _status, RP0;
MOVLW 0x03;
//MOVWF 0x20;
MOVLW 0x20 ;
MOVWF _temp ;
SWAPF _temp,1 ;
MOVF _temp,0 ;
MOVLW 0x01;
SUBWF _temp2,1 ;
MOVF _temp2,0;
MOVWF _trisa;
}Regards Ben Rowland - MatrixTSL
Hi Ben,
thanks again for your quick reply. I suspected it was the same kind of problem as we discussed earlier (http://wwww.matrixmultimedia.com/mmforu ... =29&t=8007)
I have, however, some problems with this, as I am using Flowcode for education, and my students are getting frustrated with this bug. Do you think there is any action at sourceboost (?) to fix this?
Kind regards,
Kees
Kind regards,
Kees
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
This is not a bug - it's just the way the inline assembly feature of BoostC works.
If you specifically want to interact with the address 0x20, then you can do something similar to this:
char var@0x20;
asm
BSF _status, RP0 ;
MOVLW 0x0 ;
MOVWF _trisa ;
BCF _status, RP0 ;
MOVLW 0x30 ;
MOVWF _var ;
SWAPF _var,1 ;
MOVF _var,0 ;
MOVWF _porta ;
