"Translate" C. to flowcode
ground
Post by ground »
You can translate a Flowcode by the following. C?
Thank you very much
alim876a.c
(9.59 KiB) Downloaded 456 times
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: "Translate" C. to flowcode
Post by Spanish_dude »
I did not understand your question very well.
You want to know if someone could write a Flowcode file from your C file ?
Or you want to know if that is possible ?
If it's the first question, then I'm currently busy and can't do it for you right now.
If it's the second one, yes, it is possible.
Reading through your C file I saw the French comments, so I guess you speak French and you use some French to English translater (sorry MM-admins if I can't write in another language than English) :
Bonsoir,
Je n'ai pas très bien compris votre question.
Est-ce que vous demandez l'aide d'une personne pour vous faire un programme avec Flowcode à partir de votre programme écrit en C ?
Ou bien vous voulez juste savoir si cela est possible ?
Si c'est la première question, je n'ai pas le temps pour l'instant pour vous le faire, désolé.
Si c'est la deuxième question, oui, c'est possible.
Cordialement,
Nicolas L. F.
PS: I suppose it's the first question. / Je suppose que c'est la première question.
ground
Post by ground »
Hi Spanish_dude
Yes, You want to know if someone could write a Flowcode file from your C file?
Thanks anyway.
I'm Italian, is problem that I do not know the French.
Spanish_dude wrote:(sorry MM-admins if I can't write in another language than English)
Although the board predominately uses English, we welcome postings in any language.
Spanish_dude
ground wrote:I'm Italian, is problem that I do not know the French.
My bad, I thought you spoke French.
Still, I can't do it right now.
Nicolas L. F.
ground
Post by ground »
Ok, when you have a free minute.
In the meantime I will try to do it and post it here.
Thank you very much
ground wrote: You can translate a Flowcode by the following. C?
You have not said which version of flowcode you are using.
For instance if you have V3 for PIC its no good converting with V4 as you will not be able to open file.
ground
Post by ground »
Hi medelec35
I use Flowcode 4, I would like assistance to develop a flow diagram that performs the same functions as the file c.
@ground:
Your question relates to Flowcode V4, so it should really be posted there. We have limited access to the V4 section to legitimate users of Flowcode V4 and you can sign-up for access to this forum using the "help...online resources..." menu item in Flowcode.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
To add to steves post, there is an FAQ topic which goes over the procedure to get your account updated to post on the v4 forums:
http://www.matrixmultimedia.com/support ... f=29&t=602
ground
Post by ground »
Hi Steve Hi DavidA,
I knew it already but I have a demo version, is also possible with the demo?
I would like to evaluate before Flowcode of buying.
I apologize for posting in the wrong place.
Thank you very much
The free/demo version is quite limited in terms of the number of icons allowed, so it will probably not be good enough for what you want to do. But it should be good enough to discover the potential of Flowcode.
