Preprocessor failure
Billm
Post by Billm »
Following system recovery after being virused I am unable compile in Version 3 and I get the following message.
038-001-001 Rev 2 LOOP VER WIP.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\Documents and Settings\Bill\Desktop\XP8\038-001-001 Rev 2 LOOP VER WIP.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC12F675 -la -c2 -o "038-001-001 Rev 2 LOOP VER WIP.pp" -v -d _BOOSTC -d _PIC16
Warning: can't start preprocessor
C:\Documents and Settings\Bill\Desktop\XP8\038-001-001 Rev 2 LOOP VER WIP.c(14): error: failure
failure
Return code = 1
The file could be compiled before the virus and i am still able to use PPP to program chips from existing files but am now unable to modify and code until this is cured HELP please
FINISHED
Re: Preprocessor failure
It looks like your compiler has been corrupted.
Some anti virus programs actually see the Flowcode BoostC compiler as a virus due to its name so you may have to be a bit careful when removing viruses from your computer.
Since the Flowcode file is still opening I would assume that that file itself is still ok.
Therefore uninstalling and reinstalling Flowcode should allow you to compile again as normal.
Let me know how you get on.
Billm
Post by Billm »
Will this need a new registration key?
No you should simply uninstall and then re-install and leave the key entry part blank at the end of the installation. This way your previous keys will be retained.
If you do enter your CD key again then you will need to follow it up with your existing registration details from your registration email.
