For those interested, here is a working copy of a PIC 18F2550 using the USB Slave component.
It is a simple General Purpose Input & Output circuit, consisting of the following:
8 x Digital Outputs
6 x Digital Inputs
4 x 10-Bit Analog Inputs
1 x Status LED
The device is set up to transfer 10 bytes of data in either direction between the PIC and PC.
All required drivers and source code for Visual Basic 6 are included.
Circuit requires a 20MHz crystal with 2 x 15pf capacitors for the oscilator, and 47K pull-up resistors on PORTB. For individual connections, please check the Flowcode Panel
PIC 18F2550 - USB Slave Demo in VB6
- Eric Brouwer
- Has thanked: 3 times
- Been thanked: 11 times
- USB GPIO Module.zip
- USB GPIO Module
- (189.56 KiB) Downloaded 366 times
