18F4455 Crystal ???
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
18F4455 Crystal ???
Post by Jordy101091 »
HI Guys,
I have one small question,
I recently bought a PIC18F4455 Microcontroller. But I dont have the wright Crystal. On my EB006 board there is an 19.6608 MHz crystal. But the 18F4455 doesn't work @ that frequency.
I want to use the USB functionality of this device, I don't care for Full ore Low speed USB transfer. But the questions is. What crystal should I use and what capacitance does it need.
Do I use an 48 Mhz crystal ??? pF
Ore an 20 MHz crystal 18 pF >>>> http://www.produktinfo.conrad.com/daten ... C49_4H.pdf
Can some one help me out.
Thanks.
Regards Jordy Kleian
PS. Can you expand your programming memory, I have an 16F877a this device has 8192 single word instructions and 14.3K bytes. Is there any way you can expand this.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: 18F4455 Crystal ???
Post by Spanish_dude »
I'm using a 4MHz crystal on the multiprogrammer board with the 18F4455 (and 18F2455) then you need to set the config of the microcontroller right.
It should work with a 20MHz crystal.
Nicolas L. F.
PS : http://www.matrixmultimedia.com/Learnin ... -1_Web.pdf
Take a look at the config screen on page 3, that's for a 4MHz crystal but you'll need to change the OSC Select and maybe the CPU Sys CLK Select (I think that's it) .
What Nicolas states, is spot on. The 18F4455 has a PLL multiplier. This means that with an external 4,8,12,16,20MHz Etc crystal, the Chip oscillator will run at 48MHz.
I have created a Flowchart with 1Hz flasher on port A0, and osc set at 48MHz that will work for EB006 with a 19.66MHz xtal, Since it is near to 20MHz, the PLL will work OK.
USB function should also work.
18F4455 48MHz.fcf
(4.5 KiB) Downloaded 231 times
Spanish_dude
I knew I forgot to say something !
What hasn't been told yet, is that in flowcode, you need to set the frequency to 48MHz instead of 19.66MHz or 4MHz or ...
Cheers ;)
EDIT:
... and osc set at 48MHz ...
Ah sorry I must have missed that :P
