Unable to compile to Hex
mario1
Has thanked: 18 times
Post by mario1 »
This is regarding the example flowcode files in flowcode4 pro cd.I tried to compile the example "Single servo motor control" file to a hex file.But it says failure.Any suggestions to fix that.
Mario1
1. Single servo motor control.fcf
(5.5 KiB) Downloaded 258 times
Re: Unable to compile to Hex
Hi Mario1,
Although you have not got servo connected to any ports, the main reason for failure is:
You will need to use a microcontroller with 2PWM channels (it uses CCP part of PWM) e.g 16F883, unlike 16F88 which only has one.
Same question was asked here:
http://www.matrixmultimedia.com/mmforum ... 990#p23982
