PIC configuration
achillis1
Has thanked: 91 times
Been thanked: 8 times
PIC configuration
Post by achillis1 »
I have noticed that if you create a flowchart and select as device the ECIO then if you want to change the device through the CHIP selection then the ''configure'' option is all greyed out!
Can the device be changed?
Thank you,
Andreas Achilleos
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: PIC configuration
Post by JohnCrow »
You cannot change the device in flowcode directly as the ECIO is a fixed device.
What you can do is once you have saved the flowchart, is to start a new one, select the new device you want to program and use the import function in flowcode.
This works in the same way as if you wanted to import a flowchart from an ARM or AVR device to PIC.
Think import is on the file menu.
The device can be changed by going to View -> Project options and changing the target device from the drop down menu. Once you have selected a device other then the hardware specific devices such as the ECIO the configure menu will become available again.
achillis1
Post by achillis1 »
Of course!!!
Thanks to both!!
JohnCrow
Post by JohnCrow »
Benj wrote:Hello,
Never realised you could change from the ECIO that way :)
