Flow Code is Unable to Compile these
greentech
Flowcode V4 User
Has thanked: 10 times
Been thanked: 2 times
Post by greentech »
SIMPLE OUTPUT PORT A =0 ICON IS PLACED IN A WHILE LOOP
WHEN I COMPILE IT GIVES AN ERROR
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC18LF14K50 "Flowcode1.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Flowcode1.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "C:\Users\COMMON SENSE\Documents\FLOWCODE PROJECTS\test\Flowcode1.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC18LF14K50 -la -c2 -o "C:\Users\COMMON SENSE\Documents\FLOWCODE PROJECTS\test\Flowcode1.pp" -v -d _BOOSTC -d _PIC16
Flowcode1.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "Flowcode1.obj" -t PIC18LF14K50 -d "C:\Users\COMMON SENSE\Documents\FLOWCODE PROJECTS\test" -p "Flowcode1"
BoostLink Optimizing Linker Version 6.95
Error: .obj or .lib file wrong target type
Error: Failed to process:libc.pic16.lib
Error: Failed to process:flowcode.pic16.lib
Error: Failed to process:rand.pic16.lib
Error: Failed to process:float.pic16.lib
Error: Failed to process:Flowcode1.obj
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
greentech
Flowcode V4 User
Re: FLOW CODE IS UNABLE TO COMPILE THESE
Post by greentech »
PIC16LF1823 ALSO NOT WORKING
ERROR SAYS. COULT NOT FIND CONFIG START OR END ADDRESS IN PIC 16LF1823
SAME GOES FOR ALL OTHERS.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Flow Code is Unable to Compile these
Post by DavidA »
Hi greentech,
Unfortunately this chip doesnt seem to be working properly with the current boostc compiler, we have a patch coming out very soon which should hopefully fix this as default.
In the meanwhile if you are having problems you can use the hitech compiler which should work for you.
Here is a post detailing how to set up the Hitech compiler: http://www.matrixmultimedia.com/mmforum ... =26&t=6812
Additionally would it be possible for you to post on the V4 forums for us, i will move this topic there, if you dont have access to these forums you can follow the instructions located here: http://www.matrixmultimedia.com/support ... f=29&t=602
