help - bugs only when working with ext clock
Forum for problems or queries regarding the Flowcode application and compiler usage.
hazic
Post by hazic »
when I change the fuse of AVR to internal clock the code works perfectly but when I change to external I have a lot of wierd bugs...
should I change anything in flowcode except of the frequency in project options?
Re: help - bugs only when working with ext clock
I think the default config setting for an AVR is to use the crystal frequency / 8. Could this be the cause of the problem?
Otherwise maybe you could try and explain what weird bugs you are experiencing.
