PWM over CAN
dan654321
PWM over CAN
Post by dan654321 »
I have the easy can bundle
Can any one help me ? .Can you send a Signal from a poteniometer (analog) 2.5v var to 0v node 1 , over the CAN BUS to node 2 for PWM OUTPUT.
thanks Dan.
Re: PWM over CAN
Hello Dan,
Yes this should be fairly simple to achieve, CAN is ideal for this kind of control.
Basically you will need to send CAN IDs to control the PWM operation.
Here is a basic command table, I have just made these values up so you can change to make your own protocol if needed.
ID = 1, Data Byte 0 = 1 - PWM Enable channel 1
ID = 1, Data Byte 0 = 2 - PWM Enable channel 2
ID = 2, Data Byte 0 = 1 - PWM Disable channel 1
ID = 2, Data Byte 0 = 2 - PWM Disable channel 2
ID = 3, Data Byte 0 = 1, Data Byte 1 = x - PWM Set Duty channel 1 to x
ID = 3, Data Byte 0 = 2, Data Byte 1 = x - PWM Set Duty channel 2 to x
Then all you need to do at the PWM end is to listen to the can messages and then call the appropriate PWM component macro when messages are received.
