where is An E-block (EB068)
misoct
Has thanked: 8 times
Been thanked: 17 times
Post by misoct »
Dear all
can some one tell me how to get the data sheet of An E-block (EB068) that is available for accelerometer component
also is there an example of flowcode for accelerometer components using I2C bus
thanks
Re: where is An E-block (EB068)
Sorry about that, the datasheet is now available from here.
http://www.matrixmultimedia.com/lc_index.php?p=11
Here is a Flowcode example program.
AccelTest.fcf
(7.5 KiB) Downloaded 511 times
misoct
Post by misoct »
Hello Benj
thank you for quick reply
Is accelerometer flowcode component compatable with (MMA7455 3-Axis Accelerometer Module (#28526))
http://www.parallax.com/Portals/0/Downl ... l-v1.1.pdf
thanks
Hello Misoct,
I wouldn't think so but it wouldn't take too much effort to get this working. i.e. You could always edit the accelerometer component C code to make it compatible.
The Accelerometer component was written around the STmicroelectronics LIS3LV02DQ 3 axis sensor.
