12F615/12F617, Timer1 and Timer2 interrupts are missing from component selection list.
Attached is corrected but untested 12F615.fcd file.
So may or may not work?
12F615 missing interrupts: Flowcode v4.5.18.74
- 12F615.fcd
- (10.28 KiB) Downloaded 465 times
Re: 12F615 missing interrupts: Flowcode v4.5.18.74
Same applies to 12F617.
- 12F617.fcd
- (10.46 KiB) Downloaded 541 times
Thanks Martin,
I have added these devices to my todo list so I'll give the bits you've added a good test and then once I've confirmed everything is ok I will add them to the master Flowcode file set so that they are included in the next revision.
Hi Martin,
Yes I do agree, its probably best to keep the official updates in one place and officially signed off just so we don't get in a muddle about which files should be used etc. I don't mind people posting updates like the FCD updates you made in fact usually it saves me a job and informs me of the problem but as you say updates like this should not really be posted with the official updates. Maybe we make a unofficial updates page to keep all the customer related updated together and this way I have somewhere to go and check that I have done everything before an update release.
