I am using a pic16f88 and using a PMW output. When configured to use the RB0 output it works fine however when selecting the RB3 output it will not work. I have tried using two seperate chips in two seperate cards with the same results. I have used a simple test program where the CCP1 module is enabled and then the duty cycle for it is set.
Just wondering, have i made some error or is there an issue with the configutaion bit for the multiplexed output between RB0 and RB3
Thanks for yor help
Kind Regards
Zane
PIC16F88 RB0 PMW output won't work.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: PIC16F88 RB0 PMW output won't work.
In Flowcode you need to set the configuration data correctly (i.e. the "CCP1 MUX pin" option) and select the "use alternate pin" option in the PWM component properties.
- Flowcode v5 User
- Has thanked: 93 times
- Been thanked: 76 times
Hi Steve,
Sorry about that i had a gut feeling there was something that i didn't have quite right. I put a tick in the box and all is ok...apart from my eyes.
Cheers
Zane
Cheers
Zane
