compile error (file uses V109, linker requires V113 to V113)
royalenfield
Flowcode V4 User
Post by royalenfield »
I keep getting this next error, can someone help me out with the next error:
c:\program files (x86)\matrix multimedia\flowcode v4\boostc\boostlink_pic.exe -ld "C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic18.lib flowcode.pic18.lib rand.pic18.lib float.pic18.lib "adc_leds.obj" -t PIC18F4455 -d "C:\course\projecten" -p "adc_leds"
BoostLink Optimizing Linker Version 7.03
http://www.sourceboost.com
Copyright(C) 2004-2011 Pavel Baranov
Copyright(C) 2004-2011 David Hobday
Error: .obj or .lib file Incompatible version! (file uses V111, linker requires V113 to V113)
Error: Failed to process:libc.pic18.lib
Error: .obj or .lib file Incompatible version! (file uses V109, linker requires V113 to V113)
Error: Failed to process:flowcode.pic18.lib
Error: Failed to process:rand.pic18.lib
Error: Failed to process:float.pic18.lib
failure
Return code = -2
Assembleren mislukt vanwege de foutmelding:
FINISHED
Re: compile error (file uses V109, linker requires V113 to V
It seems that during the update to V4.5 the .lib files have not been updated correctly. A reinstall of Flowcode will probably solve the problem (remember that you do not need to re-enter your licence code when reinstalling).
Alternatively, you could unzip the attached files into the "Flowcode V4\BoostC\Lib" folder on your PC.
Lib(v113).zip
(646.3 KiB) Downloaded 252 times
royalenfield
Flowcode V4 User
hi Steve
I have done this two times, the first time i have re-install flowcode v4, and i had to try the compilation,
then i had 2 errors, the i did the last update then i had the same errors as before re-install.
now i have to try some manual changes till i get another error, then i have another re-install and now i can compilation again.
but i have now no new update shoud i thry that.
Frits
Steve i will thank you for the answer
