PIC18F4580 Project
dbasnett
Has thanked: 8 times
Been thanked: 11 times
PIC18F4580 Project
Post by dbasnett »
EB006 v6
SW1 - Fast
SW2 - XTAL
ICD2 / USB - USB
PSU / USB - PSU
LVP Selection - All three set for IO Port
Flowcode Pro v4.5.18.74
FlowKit connection - PC-->FlowKit In - FlowKit Out --> EB006 USB
Custom USB Device - Matrix PICmicro Programmer - v 1.0.0.6, 12/19/2007
CPU - PIC18F4580 - http://ww1.microchip.com/downloads/en/D ... 39637d.pdf
Extended CPU - disabled
Port A - Relay - EB038 - Low Nibble (RA0 - RA3) (optional)
Port B - Switches - EB007
Port C - RS232 - EB015 - 38400 baud
Port D - LED - EB004
Port E - Sensor - EB003 - RE0 and RE1 (optional)
This is the configuration of my real project. Does anyone see any problems with the Port / Board choices?
BTW - After receiving the 4580, I changed the program that I had so much trouble downloading to the 2580, to use the 4580. It downloaded the first time, and every time since then. When I get back from school tonight I intend on starting on the above project.
Target4Tutor.fcf
(13 KiB) Downloaded 234 times
Re: PIC18F4580 Project
I have tested the 18F2580 device now and can confirm it it programming here without any problems. Can you confirm which version of PPP you are using?
dbasnett
Post by dbasnett »
PPP 3.11.15.30 FW 7
