i need a bit of help from the forum.
Situations is:
I wrote a small program for the EB063 E-Blocks.
One Block works as a sender and the other one as a receiver.
Everything works fine.
Then i got the great idea to use separte modules for the sender part from RF-Solutions so called Alpha-TX because i don´t need the receiver part.
And here my problem begins.
If i use the transceiver modules, separated from the E-Blocks and implemented in my own board everything works.
But when i use the Alpha-TX Module in the sender part, i can´t get any reaction on my receiver.
RF-Solutions Website is not available since some days an i do not know i there is any differnece in talking to a transceiver or a transmitter chip.
In the datasheets i do not see any difference in programming the receiver, transmitter or transceiver modules.
The different Pin layout is not the problem. I solved it by a self made board.
I´m not quite sure if i can use the makrocode from the EB063 for a TX-Module.
Any idea?
Andreas
