EB003 - ADC ReadAs...
What are the advantages / disadvantages of using the different versions of the ADC component ReadAs. I am currently only using the LDR and POT on board the EB003 and using the ReadAsByte. I am curious if I should be using AsInt or AsVoltage and what the difference, other than data type, is?
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: EB003 - ADC ReadAs...
AsInt provides a better level of accuracy if you need it. But in a lot of applications a byte return is more than sufficient.
AsVoltage returns a string should you require displaying the value directly.
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
ReadAsInt uses the 10 bit mode ADC and ReadAsByte make use of the 8bit mode of the ADC (correct me if I'm wrong).
ReadAsInt:
- disadvantages : I'd say you'll need to use an integer (= 2 bytes) to save the ADC value
- advantages : I'd say it's more accurate
ReadAsByte:
- the opposite of ReadAsInt
Nicolas
ReadAsInt:
ReadAsByte:
Nicolas
- Steve
Not quite. In Flowcode, the ADC always performs the full conversion. The "ReadAsByte" simply returns the top 8 bits of the result. "ReadAsByte" is probably a tiny bit quicker, but only because it is working with an INT datatype rather than a BYTE.Spanish_dude wrote:ReadAsInt uses the 10 bit mode ADC and ReadAsByte make use of the 8bit mode of the ADC (correct me if I'm wrong).
Some devices have 12-bit ADC. On these the ReadAsInt will return the 12-bit result.
In contrast some devices only have an 8-bit ADC. On these both the ReadAsInt and ReadAsByte return the same 8-bit value.
Spanish_dude
Hello Nicolas,
No your right most devices have the 10-bit ADC. I was just detailing the other weird and wonderful less common devices with 12-bit and 8-bit.
