Hi.
Once again with an other problem. This time is CANBUS, year ago i try to made a CANBUS Node with 16F876A and MCP2515 but I couldn't, in that time i solved with the PIC18F2580 That allready had CANBUS. Now I try to work again with the CAN controller and PIC but I could not make it work. I use the CAN icon of flowcode but it doesn't work out.I think the problem is in the hardware i can't find it. Maybe you can help me. I attach my schematic and my program.
Sorry for my english
Thaks a lot
CAN BUS with MCP2515 and PIC16F876A
- Has thanked: 63 times
- Been thanked: 102 times
Re: CAN BUS with MCP2515 and PIC16F876A
You can't use the CAN component of Flowcode for that.
If you use the CAN component it means you have a CAN bus into your microcontroller.
The MCP2510 is a "CAN controller with SPI interface".
This means you need to use SPI to control the MCP2510 and he'll output your data into a CAN bus.
Nicolas
Nicolas
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
The CAN component in Flowcode was originally designed to only work with this stand-alone controller chip. We later added support for the chips with internal CAN, but it should still work with this SPI chip.
I suggest you look at the circuit of our EB018 CAN interface board to see where your hardware problem may be.
Thanks Steve
So The CAN component support 18F2580????? Year ago i solved with another program.
Yes I saw the data sheet of the EB018 and then I made my schematic. I review again the data sheet but I don't see anything wrong. Well I gona a try again
Thanks a lot
Best regards
Thanks a lot
Best regards
