Help playing with 12bit bytes ??
ellisp83
Has thanked: 2 times
Post by ellisp83 »
Hi i was hoping sum body could help me?
i want to combine 2 bytes(4bit MSByte + 8bit LSByte) into a single 12bit bit
e.g 1000 combined with 11110000 = 100011110000
Does anyone know of ways of doing this in ASM, C or even flowcode V3?
I would really appreciate anyone's help with this matter :)
Ellisp83
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Help playing with 12bit bytes ??
Post by JohnCrow »
Have a look at this way of using a flowchart to combine/split 2 x 8bit bytes. Hope this might help.
http://www.matrixmultimedia.com/mmforum ... ine#p24561
Hi ellisp83,
I believe this is the link John is referring to:
http://www.matrixmultimedia.com/mmforum ... 618#p22618
If you get stuck after reading posts and looking at flowchart John kindly posted then we can help you further.
JohnCrow
Post by JohnCrow »
Hi Martin
Id just been seaching for your post, to link to that as well :)
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
int _12_bit_var; // 2 bytes
char _4_bit_MSnibble = 0x08; // 1 byte, 0000 1000
char _8_bit_LSByte = 0xF0; // 1 byte, 1111 0000
_12_bit_var = ((0x0F & _4_bit_MSB) << 8) | _8_bit_LSByte;
That should do it.
If you don't understand it, read Martin's post or just ask if you still don't get it ;).
Nicolas
ellisp83
Post by ellisp83 »
Thanks to all you guys !!!!
I am using this function to combine msbyte and lsbyte of the raw data i recieved from the SHT11 temp and humidity sensor.
So i can then perform the calculation Rhlinear = C1+C2* SOrh+C3*SOrh*
in order to get the true humidity reading to display on my LCD 16x2
Thanks to everyone again !!
Ellisp83
