Rotary Encoder
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Rotary Encoder
Just tried to download the datasheet for the EB073 rotary encoder E-Block and its linked to the EB074 slide switch datasheet.
(The link from the slide switch E-Block doesn't work at all )
- Has thanked: 63 times
- Been thanked: 102 times
Re: Rotary Encoder
I checked it out and replacing the "73" by "72" I saw this E-Block : http://www.matrixmultimedia.com/datashe ... 2-30-1.pdf
I haven't seen it before, is it a new one coming out ?
I hope I'm not spoiling new stuff
Anyways, this is something I always wanted !
Those 40 pin microcontrollers are so difficult to put in the socket.
Nicolas
Nicolas
- JohnCrow
Re: Rotary Encoder
Hi Nicolas
I spotted the ZIF board today, looks good, but its only for programming.(Its in the accessories section)
I have a 40pin ZIF in both my V7 programmers. They are not as important for the smaller chips, but it does mean you loose access to the 28pin socket under the zif socket.
If you get this type it will plug straight into the matrix programmer.
http://www.rapidonline.com/Cables-Conne ... 79908aec1a
(Matrix say in the data sheet it may be nessesary to raise it slightly with a 2nd turned pin socket, though I found this wasnt nessesary)
Personally though would not recommend keeping removing it and plugging it back in, as this is bound to wear the TP socket on the programmer.
Did you notice this complete programmer with zifs as well on the e-blocks section
http://www.matrixmultimedia.com/product ... PHPSESSID=
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Rotary Encoder
We will be officially releasing these soon.
One thing to note with the ZIF socket add-on is that this makes the EB006 a programmer only. The connections for the chip i/o lines do not come through to the E-block ports. If you want a ZIF socket and still use the EB006 with other E-blocks, then you should probably just use a 40-pin ZIF socket.
Re: Rotary Encoder
That's a bit inconvenientSteve wrote:The connections for the chip i/o lines do not come through to the E-block ports.
I'll see if I can get a 40 pin ZIF socket.
I do like the design of the case, but that's just for programming. There are no outputs to connect the E-block to.JohnCrow wrote:Did you notice this complete programmer with zifs as well on the e-blocks section.
Nicolas.
- Steve
Re: Rotary Encoder
Making the connections to E-blocks for all pins on all sizes of microcontroller would have greatly increase the cost of the add-on. You would either need a separate ZIF socket for each size of chip or a complex arrangement of relays or switches to automatically route the pins.
Re: Rotary Encoder
Me too. Is the EB073 new?JohnCrow wrote:Hi
- JohnCrow
Re: Rotary Encoder
Yes the rotory encoder and the slide switch board are both new.
I'm interested in the rotary encoder board, but I want to see the data sheet before I decide to buy one.
Im sure matrix will get the link sorted very soon
Re: Rotary Encoder
The rotary encoder datasheet is now available and the switch datasheet is now linked correctly. Thanks for letting us know about this issue.
- JohnCrow
Re: Rotary Encoder
Just ordered the Rotary Encoder, is there a flowcode test program available yet ?
Not able to find one in the test program area of the website.
Re: Rotary Encoder
Hi John,
Yes there certainly is a test program but it currently uses a customized version of the custom component. Here it is.
- EB073-12-1.doc
- (24 KiB) Downloaded 525 times
- Encoder.fcf
- (19.26 KiB) Downloaded 636 times
Re: Rotary Encoder
Hello All,
Here is a better custom component for the Quadrature encoder plus some better example files.
The custom component functions are all pretty straightforward apart from the Check_For_Changes function which has return values.
0 = No movement detected
1 = Valid movement detected
255 = Invalid movement detected, count corruption due to not sampling inputs fast enough.
Note for the IOC example to work the custom component properties must specify IOC enabled pins. On a 16F877A these pins are RB4 - RB7. The timer example can use any I/O but the timer must be interrupting fast enough so as to never miss an edge. This is obviously dependent on the maximum speed that can be applied to the encoders.
- Flowcode v5 User
- Been thanked: 3 times
Re: Rotary Encoder
Hello to all,
Are there any component macro´s available yet for the Rotary encoder board (EB073)?
I´m working with Flowcode V4.5 at the moment.
Please let me know.
Rinie
Please let me know.
Rinie
Greetings, Rinie
Flowcode V7 user
Flowcode V7 user
Re: Rotary Encoder
Hello Rinie,
For v4.5 please use the custom component listed in the previous post. Drop the custom component C file into your "Flowcode v4/Components" directory and then when you open the examples they should work correctly. Please note there is no simulation available for this.
For v5 the component is included by default.
- Flowcode v5 User
Re: Rotary Encoder
Ok, thaks Ben.
I will use this for now, we are planning on updating to V5 soon.
Rinie
Rinie
Greetings, Rinie
Flowcode V7 user
Flowcode V7 user
