I am new in flowcode and I am doing the example files implementing dspics and I have some problems:
1- the interruptions TMRx are not working in the simulator
2- the interruptions INTx also not working in the simulator
is this a problem with the FCD file like the one in
http://www.matrixmultimedia.com/mmforum ... ocb#p13464
3- I am implementing internal CAN file with a DSPic30f4012 and this ones do not have BRGCON registers, because this are 16 bit, the three registers (BRGCON1, BRGCON2, BRGCON3) are replaced for CICFG1 and CICFG2, but in the CAN initializer of flowcode just show me the BRGCON (??)
Am I doing something wrong?
I have the dspic professional installed in a windows 7 , 64 bits
normally I turn the watchdog timer off and CAN simulation is escential for me
Bugs in interruptions and CAN ?
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: Bugs in interruptions and CAN ?
Unfortunately, interrupts do not simulate well in Flowcode V4. This problem is being addressed in V5.
The CAN component config register settings are displayed in 8-bit mode (as used by external CAN) in the component property page, but are combined in the C code to produce the correct values for 16-bit devices with internal CAN.
The following code is used by the component to generate the 16-bit register values:
C1CFG2 = CNF2_VAL | ( CNF3_VAL << 8 );
C1CFG1 = CNF1_VAL;
C1CFG1 = CNF1_VAL;
